Wornandwound Affordable Vintage: 1969 Bulova Accutron Deep Sea
While Bulova/Accutron made many killer divers in the 1960′s and 1970′s, the dual crown Deep Sea has to be the coolest kid on the block. Sure, there’s the Bulova Super Compressors, and Accutron made several awesome Deep Sea and Snorkel models, but none are quite as bold as the Deep Sea.
This Deep Sea model looks like a Super Compressor with its dual crowns and rotating inner divers bezel, but it is not. The Super Compressors were of course made by EPSA and had a specialized proprietary water sealing design in addition to the iconic inner rotating bezel. Several companies in the 1960′s and 1970′s cashed in on the popularity of this design, and one of them was Accutron, who really did a bang up job.
This baby is a big ol’ chunk of solid stainless steel, measuring in at just over 41mm wide by 45mm long, with 20mm lugs. With its giant superdome thick acrylic crystal, it measures 14.5mm thick. Over all, this watch really has wrist presence. The case is classic seventies cushion style, with straight brushed finish on the top and sides, with a slim, polished angled bevel separating the two. The large dual crowns are semi-recessed into the case, and are both signed with the Accutron tuning fork logo.
From what I can gather, this watch appears to have been made from 1969 (the year my example is from) to about 1971, with the bulk of examples I’ve seen hailing from 1970. Most ones I’ve seen have a plain Jane caseback with the N0 (1970) date code. Mine has the more interesting “ballerina” back, with the highly embossed Bulova ballerina logo. This back style has the date code stamped on the inside rather than the outside. Both kinds of caseback screw in with an oversized o-ring gasket. Sadly, the gasket material that Accutron used at that time tends to break down and kind of “melt” into a sticky goo. This can be a real pain to clean off of the case when it happens.
As mentioned above, the crystal on this one is a behemoth. The high point sticks up a solid 6mm above the edge of the case. It is highly domed, and very thick, and measures a whopping 37.76mm in diameter! Like the Super Compressor crystals, this one is also nigh impossible to replace, so be wary of purchasing an example of this model with a bad crystal. As large as the case is, the addition of the massive crystal makes the watch wear even larger than its measurements.
The dial is a real work of art, with a two color / two texture finish “bullseye” style that really stands out. The inner circular part is a slate gray with a straight brushed finish. It has an applied Accutron tuning fork logo, with “Accutron” printed in white below the 12. It is also signed “Deep Sea, 666 Feet” above the 6, another classic example of the Bulova/Accutron penchant for using the 666ft depth rating. I love the “666”, it gives their divers a little something unique.
The outer portion of the bullseye dial is a nice contrasting gloss black. The hour markers are applied steel baton style with large rectangular lume filled centers. The 12 o’clock marker is doubled up. These markers are a good size, making the dial very easy to read. The baton style hour and minute hands are painted bright white with lume filled centers. A bright orange sweep second hand rounds it out. There is a day/date window at three, with a quickset function.
Ah, now for the big beautiful internal rotating bezel! This is the part that really makes this watch. There are three variants of the bezel: An elapsed time, a countdown, and a world time bezel. The elapsed time and countdown bezels are basically the same, only the orientation of the minute markers are reversed. The bezel is a nice bright white, with a day-glow orange coloring for the first fifteen minutes of the elapsed time and the last fifteen minutes of the countdown bezel. The countdown variation (shown in my pictures here) is by far the more rare of the two timing bezels. The world time bezel, of course, shows various cities of the world. Personally I’m not a fan of world time bezels, just too busy for me.
This awesome beast is powered by the classic Accutron tuning fork caliber 2182 movement. For those that don’t know, the tuning fork movement was pioneered by Bulova/Accutron (and subsequently licensed to other brands). It’s a battery powered movement that features the use of a tuning fork and electric coils for timing rather than a quartz crystal or balance wheel. They were (and still are) highly accurate and pretty durable.
The 218 is their second generation movement, and the ‘2’ at the end signifies it’s a day/date. I won’t go into the whole tuning fork story here, but you get the gist. These movements are really cool, and when you put your ear to them, you can hear the tuning fork humming. The second hand also has a really smooth sweep to it, owing to the very fine toothed gear that drives the second hand. As cool as they are, there aren’t a lot of folks that repair them, and NOS parts can be sparse. Fortunately, there are tons of the watches out there, and donor movements are more or less easy to come by.
The Accutron Deep Sea is one big, bad, vintage diver. It has so many cool little features that add up to one killer watch. These aren’t overly common, but they aren’t rare either. They can be found on eBay with regularity, and you can often find a nice example in the $500 range, give or take. They used to go much higher, but prices seem to have cooled off a bit of late. Do try to find one with a working movement and a good crystal, as well as a functioning internal bezel though, to save you some headaches down the road.
The post Affordable Vintage: 1969 Bulova Accutron Deep Sea appeared first on worn&wound.
