Pre-Order Borealis Navale
sapcmc
Administrator
Staff member
Thore are tubes not spring bars as safer for diving as they won't come out if you push the strap even with force. You can remove them via the drilled lugs. Just be careful not to damage the tubes (otherwise you can use 22mm 1.8mm thick spring bars if you often change straps).
clarencek
Apprentice WIS
Yea - figured it out - thanks. Just pushed them all the way through. Never encountered tubes like that before - there's a pin, and two tubes. Interesting.
