Can you let me know your opinions on this renders for a new diver watch we are working in?
I like this Sea Dragon trying to decide on the color to order I have it narrowed down to 2,I'll let you know which one I choose.
Case shape will be similar to Seiko SBBN015 and powered by a Miyota 9015 movement.
Will be either 300 or 500 meters water resistance. Due to case design it will not be possible to have a HEV.
It will come with a 22mm rubber strap.
Lume likely to be BGW9 applied to bezel, dial, hands.
Option #2. Same as stated above.I like option 2.
I think the solid lumped hour hand will be easier to read at night and visually it mimics the hour indices on the dial much better, giving it a more unified look.
So the hour hand does not actually have a solid flat area to later lume on it? Is it a skeletal hand?As for the hour hand it needs to have a middle separation as in option 1 otherwise will be difficult to have strong lume without a middle structure.
